CASE relearn with Aeroforce Interceptor gauges?
Old Mar 14, 2012 | 05:49 PM
Ferocity02's Avatar
Default CASE relearn with Aeroforce Interceptor gauges?
I'm trying to do the crank sensor relearn with these gauges and I'm having issues. Here are the steps that the gauge tells me to do:
1) Put in park
2) Apply parking brake and depress clutch
3) Rev engine to 4K then to 5K in 4 seconds, then return to idle when fuel cuts out
The issue I'm having is after this step it flashes to another screen that says to turn off the ignition and restart in 30 seconds. I'll do this, and it will return to the home screen without any confirmation or anything. I think it should say relearn successful or something optimistic.
The fuel doesn't cut off at 5K, so I tried again and revved it from idle to the rev limiter gradually in 4 seconds. Same result.
Anyone know what to do? Truck is in sig.
Old Mar 14, 2012 | 05:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Engine has to be warmed up all the way.
Old Mar 14, 2012 | 06:29 PM
Ferocity02's Avatar
It was at about 200F
Old Mar 14, 2012 | 06:46 PM
AndysC3's Avatar
Follow the instructions on the screen. It wont say complete or anything. Ive done it several times with the Interceptor gauge.
Old Mar 14, 2012 | 07:43 PM
Ferocity02's Avatar
I read somewhere that when it completes successfully it confirms that it was completed, and if it asks you to shut it off then it was done incorrectly.
Waiting for a response for Aeroforce
Old Mar 14, 2012 | 08:34 PM
Ferocity02's Avatar
Can you give me a detailed procedure of how I'm supposed to rev the engine when it asks me to?
Old Mar 14, 2012 | 10:22 PM
andrew383's Avatar
traveling mod
Are you turning the key all the way off or to acc??
Old Mar 15, 2012 | 09:59 AM
Ferocity02's Avatar
Back one click, so the engine turn off but everything else and the cluster stay lit up. Keeps the Aeroforce gauges on too.
Velocity1
Sep 22, 2015 01:32 PM
bluestang50
Sep 21, 2015 08:36 AM
69z-28
Sep 21, 2015 07:31 AM
zblee
Sep 17, 2015 07:58 AM
Silver8ado
Sep 14, 2015 06:35 PM
