Can you drive without a tune? For a 408 stroker?
Im having trouble getting in contact about getting my pcm retuned for my 408. I am thinking if I can get it started on my current tune then get to a dyno I can have it dynotuned somewhere instead. It might be easier this way, so I can get her back on the road sooner.
-Lurius
-Lurius
It won't idle for ****. This I know! If the injectors are the same size it may idle enough to get it out of gear, but if not, you souldn't run it anymore than you must, meaning, check for leaks and thats it.
Hello Dave
-Lurius
-Lurius
If you're still running the MAF, you can get by with the stock injectors without a problem, other than potentially having to two-foot it to keep it from dying at low-speed/idle. How far away is the dyno that you'd get to?
Originally Posted by dc_justin
What size injectors do you plan to go to? What are your new camshaft specs?
-Lurius
5 year bitches!
31lb injectors are too small for a 408
with my setup and using svo 42# ones they are at 73% duty cycle.
when you scale a svo 42 they are right around 49# injectors for ls1 psi.
you need to step up and buy some real injectors if you plan on making power
-Lurius
