Can a Vortec 350 L31...?
Old Jul 29, 2008 | 03:33 PM
04SilveradoMykk's Avatar
Default Can a Vortec 350 L31...?
Hello everyone,
If tuned properly can the L31 Vortec 350 fuel injection opperate without a crank position sensor & reluctor wheel behind the timing cover?
Essentially running the fuel injection off of the distributor trigger/cam position like the L98 TPI or aftermarket fuel injection set ups.
The computer is LS based running a 2002 G-Van 5.7L tune, I have HPTuners.
Can the comp tune even be written to delete crank position sensor?!
I know the LT1 guys are removing/deleting the CKP to run double rollers. I'm just not sure if the L31 uses the CKP only for missfire detection or to time injectors.
Thanks guys
Cheers ~Mykk
Old Jul 29, 2008 | 09:07 PM
hog's Avatar
hog
No. The PCM needs the CKP sensor data to fire the ignition.
peace
Hog
Old Jul 30, 2008 | 03:31 PM
James B.'s Avatar
I can confirm that. When I had a crankshaft break between the timing gear and the balancer the reluctor got crooked and took out the CKP sensor. The engine would not run without it - everything else was fine.
Skip Fix
22
Jul 9, 2016 07:08 PM
hodge9386
Oct 25, 2015 01:26 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 3, 2015 11:03 PM
cousblake11
Sep 9, 2015 06:52 PM
