Can someone help with these codes?
Old Sep 8, 2005 | 12:23 AM
OUT2WIN's Avatar
Default Can someone help with these codes?
We checked it with an AutoXray and this came up:
Pending Codes:
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P3001 Manufacturer Specific Powertrain Trouble Code
Freeze Codes:
I did the crank relearn saturday and also cleared a code that came up for an 02 sensor. The 02 sensor was disconnected and then when my light came up I reconnected it and then I still had the crank relearn to do. Saturday I got it done and all was well. Monday I did some g-tech times and all was still well till I got home. My check engine light came on. So I took it in today and this is what I was told. I dont understand why those codes would be going off?
Old Sep 8, 2005 | 09:27 AM
budhayes3's Avatar
PT's Slowest Truck
The first code is for the driver's side rear O2 sensor, the second is a cylinder 1 misfire code.
Old Sep 8, 2005 | 05:06 PM
moes04silverado's Avatar
THIS MAN HAS THAT ONE RIGHT.....EASY FIX TO, JUST REMEMBER TO CHANGE IT WHEN ITS COOLED DOWN.
IM NOT SURE BUT I THINK THE P3001 IS A MISFIRE CODE, WHICH BASICALLY THE COMPUTER TELLS THE ENGINE TO MISFIRE....SHOULD JUST BE ABLE TO RESET THAT CODE AND WILL RETURN TO NORMAL.....
Old Sep 8, 2005 | 05:19 PM
budhayes3's Avatar
PT's Slowest Truck
Whoops, yep I read that one wrong...was thinking P0301...sorry bout that. Not really sure what a P3001 is
Old Sep 8, 2005 | 07:36 PM
OUT2WIN's Avatar
I called the dealer and they also told me it was cylinder 1 misfire. Maybe they read it wrong also cause he kept saying "301" and I thought that was a short way of him saying "3001".
The 02 sensor deal is with my tune. Jesse says the dealer reset the rear 02s when I did my crank relearn. They should have been shut off since I got the tune cause I have no cats.
Old Feb 14, 2008 | 09:19 AM
gonzo 6.2's Avatar
What was the P3001 code?
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
