Can I run HPT on 2 computers?
Old Aug 15, 2008 | 10:41 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Can I run HPT on 2 computers?
Run HPT on more than one laptop? I got a new beater laptop and want to use it for the truck, possible problems?
Old Aug 15, 2008 | 11:20 AM
Mr. Sandog's Avatar
AFAIK the brains/registration data are in the cable, so you could load it on 500 laptops if you wanted and there would not be a problem.
Old Aug 15, 2008 | 11:34 AM
BlackGMC's Avatar
Resident Retard
I have EFI Live and HP Tuners loaded on my laptop and on my work computer .... So to answer question nope it is not a problem, if your planning on doing that I would start keeping your tunes/logs on a memory stick or flash drive that way you always have them and your not storing multiple copies at different places...
Old Aug 15, 2008 | 11:37 AM
trever1t's Avatar
I use a memeory stick and I back up to my desktop. I'm having a hard time loading, it wont accept my application key!
Old Aug 15, 2008 | 11:49 AM
trever1t's Avatar
I am trying to download from the 2.22 version on my user webpage. Seems the usb connection to the interface is not working, can't load the drivers?
Old Aug 15, 2008 | 12:10 PM
dewmanshu's Avatar
Moderately Differentiated
have you plugged your interface into the beater yet? It will need to go thru the double hardware install. That's if you are looking to use the "beater" in the vehicle. You should be able to download the software, install, insert application key and be fine. I know...BlackGMC did exactly that.
There has been reported issues with the new hpt software. I know 4 people that haven't been able to use it. It keeps crashing on their particualr setups. I haven't had issues with it.
I have HPT and my serial key on...6 computers.
Old Aug 15, 2008 | 12:15 PM
BlackGMC's Avatar
Resident Retard
I wasn't able to install the newest version on mine either, I am using the previous version on both my puters....
Old Aug 15, 2008 | 12:32 PM
trever1t's Avatar
It runs Xp and the program will start but it wont accept the app key I entered. I will go home and run the disc and see if that helps, i guess. I seem to be lacking the drivers for the interface?
Old Aug 15, 2008 | 12:39 PM
skeet's Avatar
maybe the computer, is this the old laptop you mentioned? is this the one youre trying to load hpt too. if so go into the bios and see if the usb ports are turned on or acitvated, which laptop is it? gonna wanna activate the parallel ports in the bios..
Old Aug 15, 2008 | 12:40 PM
skeet's Avatar
nevermind sorry didnt read your last post
