Can I have the naturally aspirated guys in here please? Need help with an experiment
#53
I was getting bored, and I've realized that I'm not going to have much time at all in the upcoming months. I'm going to be doing some work in several cities in the early summer and won't have much time at all for the truck. So basically I wanted to get it up and running and get this silly wideband sensor in. But like I believe and what you said, I would not go anything less than 1 7/8" on 6.0 and up. It only leaves room to grow. Regarding the turbo, I'll just hold off until more kits are being made the way I'd want to buy one. So far the only ones I've seen that use equal means of evacuating the exhaust are the Nelson kit and the Synergy Twin Kit (big bucks). Once you start using logs and things like that you have different pressures on each bank and that can't be good for reliability.
#55
#56
I've hit a constant 96-97kPA if I recall correctly with bone stock exhaust. Your reasoning would then imply that the stock exahuast is less restrictive than some header setups. I find that hard to believe. I think there's more to it.
#57
#59
#60
I think there's more to it as well and I'm not claiming I know EXACTLY what's going on. I'm just stating a flucuation in KPA readings indicate a restriction in the exhaust. Even though you may get the same KPA swing with stock exhaust vs headers, doesn't mean that the power output is going to be the same between the two. It's showing that there's a restriction with both setups. That's all.
