Camshaft Sensor???
Old Jul 21, 2013 | 09:09 PM
urdone's Avatar
Default Camshaft Sensor???
I just swapped a 6.0, vrx5 cam, port and polish heads with long tubes headers to a 2003 Silverado. Well now I get the camshaft position high input code (p0343) the truck has a hard time to turn on it backfires then turns on, sometimes it turns on normal. I just changed the cam sensor and still get the same code so I decided to unplug the cam sensor and same thing happen, it backfire then turns on but this time I get the high and low input circuit. (p0343, p0342)
I test the cam signal hi to low and low to hi on the scanner and I get 0.
The trucks idles good after starting it but I can't get this code off .
Any ideas what it can be? I'm about to take off the timing cover and recheck it.
Old Jul 22, 2013 | 09:15 AM
urdone's Avatar
Have any one run to this problem?
I've search around and found different problems with it.
Old Jul 29, 2013 | 04:16 PM
LS2? Why type of cam gear? I swapped in an LS2 in my truck and had these problems, still having the nightmare as we speak and I've tried everything.
Old Jul 29, 2013 | 09:59 PM
urdone's Avatar
Got it running already, one wire was cut of the cam sensor so I splice and it work.
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Silver8ado
Sep 30, 2015 11:42 AM
