Camshaft Sensor???
I just swapped a 6.0, vrx5 cam, port and polish heads with long tubes headers to a 2003 Silverado. Well now I get the camshaft position high input code (p0343) the truck has a hard time to turn on it backfires then turns on, sometimes it turns on normal. I just changed the cam sensor and still get the same code so I decided to unplug the cam sensor and same thing happen, it backfire then turns on but this time I get the high and low input circuit. (p0343, p0342)
I test the cam signal hi to low and low to hi on the scanner and I get 0.
The trucks idles good after starting it but I can't get this code off
Any ideas what it can be? I'm about to take off the timing cover and recheck it.
. Any ideas what it can be? I'm about to take off the timing cover and recheck it.
thompson
Dec 27, 2017 06:48 AM
