camshaft sensor
Old Apr 11, 2012 | 02:53 PM
metalman's Avatar
Default camshaft sensor
has anyone heard of a bad O2 sensor also causing a low output signal from the cam sensor? I have put a new cam sensor in, it has adequate voltage, and the wires all show ohm out and show good. So, I am at a loss as to what may cause this. I just thought maybe the computer is jacking with the timing to compensate for the lean O2 readings....
Old Apr 12, 2012 | 08:04 AM
metalman's Avatar
Does anyone have any input on this sensor issue? I really don't know where else to go with it. What all could cause the low output signal on a cam sensor?
Old Apr 12, 2012 | 08:20 AM
xx_ED_xx's Avatar
details, codes? pictures?
Why do you think o2 is the issue?
Old Apr 12, 2012 | 07:18 PM
SnakeOiler's Avatar
Did you check the wires?
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Silver8ado
Sep 30, 2015 11:42 AM
