Cam sensor pin out
Cam sensor pin out
Im almost thru with the wiring harness in the samurai. Except i just found out the cam sensor connector is missing. I got another harness that i had laying around and its missing too. But a crank sensor connector will plug in. So yhe harness has a pink/black , red , brown/white. The crank sensor connector has a light green , yellow/black , blue/white.
If i knew which pin on the sensor was signal, ground, supply it would make it easier than guessing.
Thanks guys!!!
Thanks guys!!!
Thanks man. I already have that. I need the sensor connector pin out tho. Which pin is signal and ground on the actual sensor. Sorry i didnt clarify more.
Thanks a bunch!! Now we talking.
But which one is A B C?
I wanna get this right the first time. With the intake turned backwards and the air filter in the cab its gonna be hard to get to the connector again.
Thanks again!
Thanks again!
WarbirdLS1
08-08-2015 10:53 PM
mr03silverado
07-17-2015 02:15 PM
