C6 90 mm FBW Throttle Body Not Fully Opening
#22
If you take a look at the intake manifolds on the cars and trucks (profile) that use the 90mm TB, you will notice that the TB does in fact open 100%. GM laid the throttle body back (i dont remember the exact angle) to help with tip in drive ability. If you were to open the blade to what you would think is 100% it would obstruct the air path.
Besides, I've communicated with DR. X and they have confirmed that there is a difference between the two and that they were working on a harness, but the lack of demand caused them to shelve their prototype. Also, if you look at the install instructions on their website, it is clear that there is a difference between the truck 87mm and the car 90mm throttle bodies, since you have to cut two looped wires on their harness for the the car TB, whereas you don't for the Truck TB.
Maybe there just isn't enough people out there who actually checked to see if their 90mm TB is actually physically going to WOT on their trucks. I did, and I know mine doesn't. AND, worse yet, there doesn't seem to be a fix.
#25
The stock one does go full WOT. I am going to port it but I want to do a couple of baseline runs first, N/A and w/ the Nitrous, so I can see what difference, if any, it makes.
#26
Here's what the two throttle bodies look like side by side. You can see the large ridge on the Truck TB (the one with the gold throttle blade).
Note also that the blades rotate in different directions (NB: one of the photos shows the truck TB upside down).
#27
Un-Registered User
not to be a smart *** but, couldnt you just bolt the car throttle body upside down to make the throttle blade open the correct way? i know it doesnt fix the 100%wot but if the bolt pattern is the same and you have clearance, its a thought. what wires on the tb are coorelated to the ones you cut for the dr.x harness?
#28
CI Denali, After seeing your pictures I noticed that your throttle body has the truck ridges, what year 6.2 do you have. Here are pictures of my 09 TB without the ridges. It measures 3.440 inches across the narrowest point (old school venturi) in both directions, top to bottom and side to side. What are you inside diameter smallest dimensions?
#29
#30
I can't remember exactly, but there are two looped wires on the dr. X harness that you have to cut to run the 90mm. If you look at the install instructions on their website you'll see what I'm talking about. I'm still convinced that there has to be an easy tuning/voltage adjustment fix out there somewhere...
