Blinking battery light???? help!!
Old Jun 11, 2007 | 09:51 PM
nonnieselman's Avatar
Default Blinking battery light???? help!!
Hey guys, i just done a Calflash with the 12212156 OS and a crank relearn... Now i have a flashing battery light.. WTF?
Code P1638 "Generator F-Terminal Circuit"
Whats all this about???
I need help fast because i have to drive tom...
Old Jun 11, 2007 | 09:58 PM
Derek @ EDO's Avatar
FormerVendor
no big deal man, just disable the code! it wont hurt anything.
Old Jun 11, 2007 | 09:59 PM
OK i was fixin to get mad agina... haha thanks bro.. fixin to disable it right now... and then start on the tuning...
got to install a 2 bar map and fix up a COS...
Old Jun 12, 2007 | 01:55 AM
thunder550's Avatar
High on diesel fumes
The reason it's on....99-00 trucks are 2 wire alternators. They have the main charge wire and the L-terminal to "turn on" the alternator and tell it to start charging. In 01 they also started using the F-terminal, which is a field sense wire that provides some sort of feedback from the alternator to the PCM. Since you upgraded to a newer OS, your PCM is now looking for the F-terminal signal. As DLH said above, you can just disable that code and you'll be fine.
Idryfly5
Sep 2, 2022 08:55 PM
RustyD
May 23, 2016 07:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
