Battery Voltage
Old Oct 15, 2008 | 12:49 AM
aaronmc's Avatar
Default Battery Voltage
I can download all the settings from my pcm and save the tune file but when I go to upload the new tune with the changes I get "battery voltage to low or to high" and then it says the upload was successful. When I take a reading again the changes are not there and everything is the same. I made sure all my interior light are off and the battery is not dead. Anyone have an idea of whats wrong or some way to get around this?
Edit: This is in EFI Live.
Old Oct 15, 2008 | 12:53 AM
nonnieselman's Avatar
what is your battery voltage?
I tried tuning a buddy of mines truck and it gave me that message, but his battery was on its way out so i hooked up jumper cables from my truck to his and waited about 15 mintues..
It worked after that. The next day he called me and said it died.. wouldnt crank when he left school.
new battery and all is good now...
Old Oct 15, 2008 | 12:56 AM
aaronmc's Avatar
The voltage hovers alittle over 14 and ive been driving my truck since and has yet to not crank.
Old Oct 15, 2008 | 01:02 AM
do you have the scan tool with EFI Live?
Im guessing you have one of Justin's boxes?
Old Oct 15, 2008 | 01:04 AM
aaronmc's Avatar
Yes I have the scan and tune tool.
Old Oct 15, 2008 | 01:07 AM
connect the scan tool. and log the PID
Battery Voltage GM.VOLTS
That will give you a exact reading..
Connect and see what it is with your key on but not cranked...
Old Oct 15, 2008 | 01:08 AM
aaronmc's Avatar
What should it be at?
Old Oct 15, 2008 | 01:11 AM
mine usually sits at 11.8 with the key on, engine off... and 13.6 with the engine running..
Old Oct 15, 2008 | 01:13 AM
aaronmc's Avatar
Ill check it out tomorrow and see what its at. Do you have any idea what the allowance is voltage wise in EFI for tuning?
Old Oct 15, 2008 | 01:15 AM
Man i dunno... have you been on http://forum.efilive.com/ ?
They may be able to help you more..
