battery not charging
Old Feb 27, 2011 | 09:24 PM
outlawz2004's Avatar
Default battery not charging
for the last couple days, been having problems after starting, the battery light and "battery not charging" showing up. The first time it happened, took a few minutes and then shot up to normal voltage. Today it did it several times, shooting up to normal after a few minutes, revving seems to help it get there quicker. Once today, it got to where it would barely idle, then voltage went up to normal and light went off. I guess its safe to say I need a new alternator, unless someone has a different opinion.
Old Feb 28, 2011 | 04:59 AM
anyone?
Old Mar 1, 2011 | 03:28 PM
krambo's Avatar
I think you are on the right track...
1. How old is the battery?
2. Have you cleaned the terminals lately?
3. What is the belt condition?.....
Old Mar 1, 2011 | 04:06 PM
Mangled03gmc's Avatar
Baltimore Whore
Check the battery studs, make sure that the cables are tight... Then go from there..
Old Mar 1, 2011 | 06:22 PM
battery is new, a couple months old. All new studs. Had the alternator tested today, failed every test. Before I took it off, I sprayed it with electrical cleaner and it was actually working right. I just went ahead and bought a new one today and its all good. I tell you one thing though, I used to buy those cheap $20 drive belts and they wouldnt last that long, I bought an $80 belt from Napa about four years and 100,000 miles ago, the thing still looks great, not a single crack, no wear showing. It may have stretched a little but that doesnt matter because it was a little shorter to begin with.
RustyD
May 23, 2016 07:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
JordanH
Sep 12, 2015 12:02 AM
