Bad MAP ??
Old Jun 16, 2007 | 11:16 AM
Raffman's Avatar
Default Bad MAP ??
Just installed my Aeroforce scan gauge and its cool but I noticed one thing.All the gauge readouts match up except manifold pressure,its reads lower than my vac/boost gauge by 9 or so psi. Does this indicate a bad or leaking MAP? It might explain a very incosistant bog/flutter at WOT that I still have. Maybe the boost from the procharger did something to it???
Old Jun 16, 2007 | 11:42 AM
thunder550's Avatar
High on diesel fumes
Your stock MAP sensor is a 1-bar, meaning that it's only good to read vacuum. If you really want to use the "boost gauge" on the Aeroforce gauge, you need to install a 2 bar MAP sensor and calibrate the PCM to read it.
Old Jun 16, 2007 | 12:15 PM
Raffman's Avatar
Would it really change anything performance wise to go to a 2 bar? The difference in the readings are on the vacumn side, thats why I thought something was wrong.
Old Jun 16, 2007 | 12:55 PM
thunder550's Avatar
Most boost gauges read vacuum in hg-in instead of PSI. Make sure you are comparing the same units.
The only way to take advantage of a 2-bar MAP sensor is to load in a custom operating system in your tune and go to a 2-bar speed density tune.
Old Jun 16, 2007 | 01:40 PM
Raffman's Avatar
Thanks for the info. Sounds like something for down the road on the 2 bar. on the gauge I'm pretty sure its in. of vacumn????
Old Jun 16, 2007 | 01:45 PM
thunder550's Avatar
Inches of vacuum is different than PSI vacuum. I doubt you have a problem, the two gauges are just measuring in different units. Your boost gauge reads inches, and your Aeroforce reads PSI.
calsdad
Jun 14, 2023 11:07 PM
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
