B4206 enable or disable during AutoVE tuning?
Old Oct 12, 2007 | 10:47 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by dc_justin
Working on an 05 right now and it does have it.
06s have it.
07s have it.
So basically everything except Customs OS's, right?
Old Oct 12, 2007 | 10:50 AM
dc_justin's Avatar
Hello Dave
Yep. It's in there in COSs too, just hidden.
Old Oct 12, 2007 | 10:52 AM
BlackGMC's Avatar
Resident Retard
Thanks Justin, Ok so now why is it not in the tutorial???
Old Oct 12, 2007 | 10:57 AM
dc_justin's Avatar
Hello Dave
That, I do not know, I don't really follow the tutorials.
Old Oct 12, 2007 | 11:29 AM
BlackGMC's Avatar
Resident Retard
I can understand, but for us newbies the tutorials are the only thing we have.....
Old Oct 12, 2007 | 11:30 AM
dc_justin's Avatar
Hello Dave
That's why I've no problem helping out when I can.
Old Oct 12, 2007 | 11:52 AM
BlackGMC's Avatar
Resident Retard
I have another question about the tutorial, is it necessary to increase the AFR in upper MAP regions in the B3605 - Commanded fuel When in Open Loop
table if I am going to be using the MAF? IMO I think that table should be left alone cause PE will take care of those regions when enough load is present, is this correct?
For example (sorry the pics are not in F* and AFR, I have since changed):
Stock
Suggested by tutorial
Old Oct 12, 2007 | 11:56 AM
dc_justin's Avatar
Hello Dave
You can use either technique. I personally prefer to keep PE active and leave that table alone. MAF alone has no bearing on it however, since the PCM still uses the MAP value to determine fueling requirements in that table.
Old Oct 12, 2007 | 11:58 AM
BlackGMC's Avatar
Resident Retard
Ok, that makes since, Justin I really appreciate the input!!!!!
Old Oct 12, 2007 | 08:40 PM
HD6.0l's Avatar
Banned
Don't you think you aught to tell someone to add this to the tutorial if it so important , several people have used the tutorial with success and not seen this .
So effectively no one has ever went into OLSD without this .
A lot of messed up SD tunes .
Yeah COS3 does not have it or can't see it if it does .
I thought when the MAF failed the PCM used {B3605} anyways or {B3647} in COS ?
