Auto VE
Old Sep 13, 2008 | 03:29 PM
RED04REGENCYRST's Avatar
Default Auto VE
i have the rtt setup on my truck, but i cant use the auto tuning setups. i have use the search button, but i must be looking for the wrong things cuz im lost and dont know how to set it up. i even looked over on hpt forums. so i guess the search button is > me. TIA for any help you guys can give me.
Old Sep 13, 2008 | 03:55 PM
kbracing96's Avatar
If your wanting to use the "auto tune" button that uses live wideband data to correct the VE in real time, HPT has never implemented it. There's a button, but it's never been functional (grayed out).
Old Sep 13, 2008 | 04:34 PM
ah ok. so the auto ve yall are talkin bout is on efi live?
Old Sep 13, 2008 | 04:49 PM
kbracing96's Avatar
AutoVE in EFILive is like using the histograms in HPTuners. Your just mapping the data in a graph of the difference of the commanded AFR and the actual AFR via the WB and then adjusting the VE table using that data.
However, if you have a RoadRunner PCM and EFILive you can auto tune in real time with the WB O2 directly changing the VE table,
Old Sep 13, 2008 | 04:53 PM
charcold-bowtie's Avatar
Kyle have you ever used a RR. They seem pretty kick *** although i dont need one.
damn i missed out again. thanks for the info.
Old Sep 13, 2008 | 05:14 PM
kbracing96's Avatar
No, I don't have the $$$ for one
Old Sep 13, 2008 | 05:26 PM
BlackGMC's Avatar
Resident Retard
how much is RR??
Old Sep 13, 2008 | 06:13 PM
around 600 dollars
http://www.moates.net/index.php?cPath=53_56
Old Sep 13, 2008 | 06:43 PM
kbracing96's Avatar
Don't forget the License from EFILive needed too, $200.
