Anyway to install updated software from a newer ECM to year older ECM? Speed Density
Old Jun 24, 2014 | 07:29 PM
Three6GMC's Avatar
Default Anyway to install updated software from a newer ECM to year older ECM? Speed Density
Alright I want to do a full speed density tune in my 2011 but for some reason my programming does not support it in HP Tuners. Now my buddies 2012 Silverado does support a full speed density tune. Both started off basically the same truck 5.3/6 speed except mine is a 2011 4wd and his is a 2012 2wd. Both have the same e38 ECM. Is there a way I can just copy and paste his tune file into mine and it work? Never done that before and neither has my tune on the newer vehicle so I'm unsure. Anyone out there do this before or know how to do a full speed density tune on a 2011 like mine? Right now I'm idling off the Maf and the Maf is all over the place reads really high and really low when I plug up the vacuum port I have open so it will idle right. I have to have a small vacuum port after the throttle body open just so it idles fine and I need to fix that asap. Seems like it's getting a lot of turbulence with the turbo. Also I'm on a ls7 Maf.
Old Jun 26, 2014 | 11:09 PM
subeone's Avatar
it is OS mod locked im assuming
os upgrades are free now..hptuners is being really generous now, so go ahead and apply the 2 bar upgrade.
Old Jun 27, 2014 | 02:52 AM
Three6GMC's Avatar
Not sure what you mean... Make a custom OS and I will be able to do the speed density tune? I imagine my tuner has tried that as he has done that with several other vehicles in the past. I'll be at the shop tomorrow trying some more things out. You have any idea if I were to copy my buddies tune file into my truck and make adjustments from there would it work? I have seen the older ECMs write corvette tunes into Camaros and stuff like that but not sure on these newer e38 ECMs.
Old Jun 27, 2014 | 04:38 AM
subeone's Avatar
as long as you have the same tranny same controller you can do a write entire of ur buddies tune in urs or vice versa. Just do the obvious of removing vats and what not
Old Jun 27, 2014 | 09:12 AM
Three6GMC's Avatar
ok great ill try that and see what happens... wierd how hp tuners doesnt have a custom os option for my truck but they do for all the other ones.
Old Jun 27, 2014 | 08:59 PM
Frigg!! I just upgraded to 2 bar on my truck a couple of months ago...cost me 2 credits!!!
Old Jun 30, 2014 | 03:23 PM
Three6GMC's Avatar
Good news my tuner reflashed my ecm from my buddies 2012 updated file and worked perfectly. Did the custom os and now im full speed density. Trucks idles and dailys perfect and runs great wot.
5.3Okasai
Mar 9, 2022 01:07 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
mzoomora
Jan 3, 2016 07:06 AM
creekrat
Aug 2, 2015 01:27 AM
