Another wideband thread
Old Jun 17, 2008 | 03:24 PM
Spoolin's Avatar
GFYS and STFU
Originally Posted by dewmanshu
I have been meaning to unstick those articles for that exact reason. I have DynoJet and it interfaces just fine as well. Maybe because there are more Innovative products out there, but I certainly read more trouble threads dealing with the LC-1. Innovative is the trusted tailpipe set up, so who knows. But I am glad I caught this thread...unstickying those wideband comparisons now.
I didn't see this until now...never mind the last question in the other thread!
Old Jun 17, 2008 | 04:00 PM
Derek @ EDO's Avatar
FormerVendor
Originally Posted by sprayed8
Another question. i the PLX says it has the ability to act like a narrowband for the vehicles computer, does that mean that i can remove one of my factory O2s and replace it with the PLX wideband so i dont have to weld in another O2 bung? sorry, i'm a newbie to WBs.
Hey man, Ill explain how the PLX emulation works. Im glad you mentioned this because it is asked alot
A narrow band reads 0-1V 0 being lean and 1 being rich
A wideband reads 0-5v 0 being lean and 5 being rich
PLX has integrated a scaling feature which puts out 0-1v based upon the wideband reading of 0-5v.
So in short terms the 0-5v is "converted" to 0-1v and sent back to the PCM.
This in turn still tells the PCM if the vehicle is in a lean or rich state without actually having a narrowband sensor.
So yes, you can remove your narrowband and replace it with the PLX wideband setup and still maintain your NB readings and functions from the PCM due to PLX's emulation feature.
Hope this helps,
Derek
Old Jun 17, 2008 | 04:13 PM
sprayed8's Avatar
Thanks a lot Derek that's exactly what i was looking for. PLX it is then.
Old Jun 22, 2008 | 03:21 PM
southern_chevy's Avatar
Anyone know what wire to tap into on the nb to make this work?
Old Jul 5, 2008 | 10:16 PM
RED04REGENCYRST's Avatar
i have a plx and am very interested to know bout this as well. with some digging into old post i ran arcoss this....
https://www.performancetrucks.net/fo...ight=o2+wiring
but both say that the purple is the high input and the tan is the low input. the plx only gives you one wire, so which do you hook it up to?
Old Jul 8, 2008 | 11:59 AM
FormerVendor
Make sure the wire is inserted into the top right slot on the analog connector that plugs into the sensor module.
As far as tapping into the 02 harness wire, try the high signal.
Thanks,
Derek
Old Jul 8, 2008 | 04:20 PM
yea, that one seems to be working. the purple wire that is
Old Jul 8, 2008 | 09:23 PM
v8
17,16,15,14,13,12,11 Drvr
so I take it, it will hook straight up to HPTuners proversion, the PLX is what i'm referring to, thanks.
Old Jul 8, 2008 | 09:37 PM
FormerVendor
Thats correct.
SS94S10
Jan 3, 2019 01:57 PM
trevorh1
Sep 27, 2015 08:47 PM
madmann26
Sep 6, 2015 04:19 PM
