Another $400 paperweight!!!!!!
Old Nov 24, 2008 | 01:13 PM
-HIC-'s Avatar
No joke! Maybe that is why I only cut a 1.67 60'~ I did not know the stall police were under cover at the track with us Friday. I mean jeeze I had my scanner on I know what my tranny temp was. I dont even really brake stall on the line, he must be hearing the power and mistaking it for stalling.. It was however a clever way for him to get this thread off topic. I was simply letting the original poster know that ETC will have no negative effect on acceleration as long as the tune is setup correctly.
B
Old Nov 24, 2008 | 01:44 PM
Ok just got back! It runs really good now! Removed 100%tq management and also used a wideband 02 senor and it was running 12.6 @ WOT. There is a noticable difference with a custom HP tuners and a programmer.
Old Nov 24, 2008 | 05:04 PM
dc_justin's Avatar
Hello Dave
Originally Posted by -HIC-
It would not throw a lean code in PE mode. Bottom line is that 14.7 in PE mode is WAY lean, I mean dangerous. Like mentioned before your AFR in PE should be 12.8-9.
It's not in PE at the time. Some 2006 and 2007 classic Operating Systems have "quirky" PE activation. It's common for them to not enter PE mode for the first few ignition cycles after a tune and at random times otherwise, even when all conditions have been met.
Old Nov 24, 2008 | 05:19 PM
phasemaster1's Avatar
After a few cycles would it then settle and remain?
Old Nov 24, 2008 | 05:22 PM
-HIC-'s Avatar
I am sure you are correct. However the point of my post was 14.7 at WOT is dangerous.
Old Nov 24, 2008 | 06:59 PM
Wheatley's Avatar
Truck Sponsor
Seen that several times.LOL
Old Nov 24, 2008 | 08:12 PM
-HIC-'s Avatar
This is silly. If you start out with latest base tune for a certain year model it will have the "fixes" already installed. You will run into these issues when starting out with original base tunes that had bugs, that have since been corrected. This is the reason your computer is flashed at certain points when you take your vehicle to the dealer. You can think of this as a patch for windows. The OEM finds a fault, and fixes it when your vehicle is in for service.
I simply stated that:
1. your vehicle will not throw a lean code in PE mode.
2. Your AFR is WAY lean at 14.7 at WOT
Nothing more, nothing less. If you guys want to take this post off topic, go ahead. I will not be part of it.
Old Nov 24, 2008 | 08:15 PM
Wheatley's Avatar
Truck Sponsor
who are you?
Old Nov 24, 2008 | 08:20 PM
dc_justin's Avatar
Hello Dave
Not sure who you're directing this at, I was just stating WHY it was 14.7 at WOT, not the ramifications of doing so.
Old Nov 24, 2008 | 08:21 PM
-HIC-'s Avatar
Originally Posted by Wheatley
who are you?
-HIC-
Does it matter?
