Annoying surge with AC on, i am at a loss...
Old Apr 30, 2012 | 08:47 PM
BlackGMC's Avatar
Resident Retard
Default Annoying surge with AC on, i am at a loss...
Well my truck has an annoying surge when coming to a stop with the AC on... The RAF is dialed in +/- .5... I just can't seem to figure out what is going on...
This all started when i added the 4L80 and CircleD converter... When the AC is off, i have no issues...
Old Apr 30, 2012 | 09:03 PM
GMCtrk's Avatar
Ive had the same issue on mine for several years now. Its just a very light jerking when the compressor cycles and it can only be felt in OD. Ive just chalked it up to a slowly dying compressor. The belt is really worn so maybe its that or maybe the pulley is going. I dont know...it started when the 6.o was stock and with the stock trans. So the cam n 4l80 had nothing to do with it. I modified all the parameters in the a/c tune that i thought could affect the jerking with no luck, so its something mechanical.
Old Apr 30, 2012 | 09:06 PM
BlackGMC's Avatar
Resident Retard
it is not jerking, it is surging only when coming to a stop, between 0-15mph...
Old Apr 30, 2012 | 09:17 PM
2007chevy5.3l's Avatar
Mine does the same ****. Pisses me off cause IDK what it is. Everything is spot on and wont do it when AC is off. Im kinda thinking my compressor clutch is going out again
Old Apr 30, 2012 | 09:20 PM
BlackGMC's Avatar
Resident Retard
Ya have never ever had this issue...
Old May 1, 2012 | 12:49 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
A/C torque management? I don't have EFI, so I can't help much.
Old May 1, 2012 | 04:48 AM
Gadgetized's Avatar
Can you post a log of it happening please?
Old May 1, 2012 | 07:46 AM
LS1TRUCKGUY's Avatar
mine always did the same thing as well... wheatley had hours of seat time trying to get rid of it, but no luck... occasionaly it would do it in park and would start surging until it died... tune was spot on, and it never did it with the a/c off. we even swapped from the 00 pcm to an 02 pcm. it help a little, but didnt fix it. i almost think maybe an orifice was plugged, and the engine had to work harder to turn the compressor when it engaged. not sure though
Old May 1, 2012 | 11:32 PM
oakley6575's Avatar
Also have similar issues. I have tried multiple times to get some professionals to explain what each A/C torque table does but no one seems to know. It's pretty frustrating.
Old May 2, 2012 | 01:19 AM
BlackGMC's Avatar
Resident Retard
I am getting it figured out. I had to spend about 2 hours yesterday figuring out those ac tables then another 2 hour dialing them in. Oh and another hour making a custom PID to log the damn ac pressure. RAF with the AC on amd off is within +/- 0.4. It is idling pretty damn good. Tomorrow will be the true test to see if it is fixed.
