To all:
Old Oct 15, 2006 | 08:49 PM
12sec.5.3's Avatar
Default To all:
Are you guys still running stock ve tables or did you make changes or tune them? Just curious....
Old Oct 15, 2006 | 08:55 PM
speedy02's Avatar
I started to modify my ve table after i removed the cats when i had stock cam and no headers.
Old Oct 15, 2006 | 09:15 PM
kbracing96's Avatar
Mine has had ALOT of autotuning done
Old Oct 15, 2006 | 10:14 PM
mines had alot of work as well
Old Oct 16, 2006 | 05:53 PM
12sec.5.3's Avatar
Has anyone who's done the 6.0 swap ever tried running a stock 6.0 ve table? I'm having trouble with fuel. It seems to be okay until I hit 3rd then gets really rich.
Old Oct 16, 2006 | 07:19 PM
Bowtie70SS's Avatar
I don't know if I can adequately explain, but I'll try. To my knowledge you run off of the Power Enrichment table at WOT or PE mode. The only thing the VE table would affect is from the LTFT's or Long Term Fuel trims...when you go into PE mode your vcm uses the last trim reading along with the PE multiplier. I would say either your fuel trims are out of whack, your MAF needs calibrated, or you are commanding too rich of a mixture in PE mode. Did you tune it yourself? Using a wideband? This info will help us figure your problem out.
Dave
Old Oct 16, 2006 | 08:33 PM
12sec.5.3's Avatar
Yes, I'm tuning myself. So ve does nothing at wot? I have a h/c 6.0 lq9, 02 5.3 ve table, and stock MAF cal.
Old Oct 16, 2006 | 08:41 PM
whoa, you are running a 5.3 tune?? thats way lean for the 6.0
Old Oct 16, 2006 | 08:56 PM
Okie5.3's Avatar
take a look at your IATs when doing a run. IATs are prolly up there a bit at the start of a run dropping pretty quick by the time 3rd rolls around, all in all making you a bit lean at launch and going rich up top.
Old Oct 16, 2006 | 09:08 PM
12sec.5.3's Avatar
I was running a 6.0 ve that I modified a bit. I downloaded it from efilive's website. I was having a bunch of issues so changed to the 5.3 ve table yesterday. I'm fighting my spark tables right now with detonation. I'm commanding 26* and getting 33*!! WTF!! I've zero'd out the IAT multiplier and still nothing.
