AFR readings way off between different WB
#21
I did another free air calibration on the sensor and now it is reading correct. 14.x at idle and 11.6-12.0 @ wot. It is still reading 14.x @ up to 3psi. So maybe the PE table needs tweaked. Other than that everything seems good. I dont hear any knock when its at 14.x in boost. If anybody wants to tell me how to log with EFI and check for KR, I'll be glad to listen. I havent played with the scan tool too much yet.
#22
Moderately Differentiated
maybe dc will chime in. I treat everything up to 100kpa just the same as any n/a guy does. You can get away with 13:1 afr in this area but trail off quickly as it goes through the kpa levels (i am at 12.9 at 105kpa). Ky your 2bar right? 1slow..you 2bar? if you are 1bar, you're pe settings are probably a little high. rpm engage? map? pe enable tps? This is the fun part of tuning IMO.
#23
I am 1 bar. PE enable at 85KPA 40% TPS. I see PE (open loop) sometimes and not in boost. Saw a few bits of KR logging so I adjusted to 12.8 AFR in that area, those conditions. Usually climbing a hill on the highway in cruise control. OD and TC locked.
Wish I had been logging a recent long hill pull I made with a trailer and a safe on it. Maybe 2000 lbs. Truck never kicked out of OD nor did the TC unlock. Kept building boost, meth kicked in, wound up at about 7 psi boost to maintain speed. Thought about pulling it down to 3rd but said the hell with it. Just to see if it would pull it. Probably went through 1/2 gallon of meth though.
#24
#26
You may as well be speaking Chinese to me.
I will try to figure out how to log and see what I find. I dont know how to check Kpa v. rpm etc, or how to tell when I am getting into PE. I have EFI live. If you want to tell me how I will check it out.
#27
#29
11 Second Club
#30
Texas terminator, got your PM. Thanks.
I did some logging today on the way to work. Pretty much hit all the driving conditions other than a WOT run (traffic sucked)
I saw a max of 2.4* of KR for the whole drive but it stayed under 1.3* most of the time. Well, it stayed at 0 most of the time but when there was KR it was .9 or 1.3 etc....didnt happen enought to concern me. Seems to be happening around the 2-3 shift.
Anyway, anybody know where I have to adjust the TPS% for the PCM to go into Open Loop (OL)? I actually sat at 3psi and 15:1 AFR today until I let off the gas. If I give the pedal a quick stab it drops right into OL but, if I ease into it I can get up to 3psi before OL kicks in and the AFR drops into the 11's as it should.
So what table do I need to look at?
