AFR at Idle......Please look.
Old Jul 3, 2007 | 06:11 PM
nonnieselman's Avatar
Default AFR at Idle......Please look.
Hey guys,
Im tryin to figure something out...
What is the AFR suppose to be while at idle???
Ive got No cats, STS, and my WB O2 is about 18" after the Turbo.
And this is a screen shot of my Idling... attached is the Log.. (Used EFI Live)
You can see at the top of the screen in blue, Value=15.94
Min=14.42 Avg=15.62 Max=16.46....
Commanded is 14.68....... what gives?
Thanks guys!!!!!
File Type: efi
Old Jul 3, 2007 | 08:37 PM
67SS509's Avatar
10 Second Truck Club
First go to the PID you use for logging and get rid of one parameter to get the channels down to 24. At 25 channels you are only getting 5 frames of data per second instead of 10.
Then go to your VE table and cut 10% of your fuel at 800 rpm all the way across and see what affect that has.
Old Jul 4, 2007 | 01:35 AM
I completely forgot about that.... Thanks Man!!!!!!!!!
Im fixin to go redo my AutoVE and double check my VE tables.....
Old Jul 4, 2007 | 06:53 AM
67SS509's Avatar
I had a brain fart on that one! I should have said add 10%
Old Jul 5, 2007 | 02:53 PM
Its cool.... i knew what you were talkin about... i got it to bout 14.8ish now... alot better than 15.5 or so...
BoostedBowTie
Jan 3, 2020 06:46 PM
project-pegasus
Sep 18, 2015 08:22 PM
creekrat
Sep 10, 2015 12:59 AM
mz00516
Aug 23, 2015 12:19 PM
darnie
Aug 10, 2015 10:25 AM
