Ac fuse blows when turned on
Old Aug 21, 2016 | 12:07 PM
726.0chevelle's Avatar
13 Second Truck Club
Default Ac fuse blows when turned on
I have been pulling my hair out testing and trying different things. Every time I turn on my ac on my 2006 it blows a fuse. I hot wired the compressor and it kicks on and runs. I've unplugged the blower motor and same thing. Been searching for cut or burnt wires with no luck. Has anyone had this problem or heard of this any tips would be appreciated.
Old Aug 21, 2016 | 08:09 PM
MikeGyver's Avatar
Do you have access to an amp meter? If you could test the amp draw through your hot wire, that would tell you if maybe the windings in the clutch electromagnet are bad. It might have a short that causes it to pull more amps than allowed by the fuse, but enough of the windings are left that it will work with a hot wire.
Old Aug 22, 2016 | 01:23 AM
Wolftrk99's Avatar
I have seen a bad relay cause the ac fuse to blow!
Old Aug 22, 2016 | 06:23 AM
Can you just change the clutch on the compressor?
Old Aug 22, 2016 | 06:30 AM
I'm thinking it's either the relay or clutch windings.
Old Aug 22, 2016 | 09:20 AM
Wolftrk99's Avatar
The clutch can not be replaced without tearing up the compressor
mischiefse7en
Oct 28, 2016 11:42 PM
camar0corey
Jun 29, 2016 06:52 PM
11z71turbo
Jun 22, 2016 04:57 PM
walidmurad
Jun 4, 2016 12:08 AM
walidmurad
Jun 2, 2016 08:10 AM
