'99 5.3 Has a Bad Misfire and Codes
Old Jan 9, 2014 | 06:11 PM
  #21
55Hdtp's Avatar
Registered User
Sorry about the lack of updates. The weather here has been bad lately and I've had a lot of other things going on. I'll give results as soon as I can find the time to do the diagnostics.
As far as grounds, I had already checked all of the grounds. They are intact and tight, but the ground at the battery terminal did have some corrosion. I cleaned it, but there was no change. I haven't tried the relays yet.
On another note, I forgot to mention for the past couple of weeks it has had a weird issue that may or may not be related. When I turn the key, it starts for second and then immediately dies. It does this over and over every time I try until I turn the key to the off position for 10 seconds then, when I try it fires right up.
Old Jan 12, 2014 | 11:12 PM
  #22
nightmare99-__-'s Avatar
Registered User
Sounds crank sensor related like i mentioned before, if you get the time pull the main belt off and do whatever you can to tryand tug around on the crank. If not try a new crank sensor and relearn?
Old Jan 12, 2014 | 11:14 PM
  #23
Registered User
Nevermind just reread that you already did that. Sorry!
Old Apr 29, 2014 | 04:16 PM
  #24
55Hdtp's Avatar
Registered User
I always hate reading through forums, finding problems that sound like mine, and then there is never a conclusion, so I wanted to give the final word on my problem. I know it's been a while since I've given any updates, but I haven't had any luck until this month. I did some more reading and troubleshooting, and I finally figured out the problem. The driver's side fuel rail had a lot of black soot in it that had accumulated at the end of the rail and had stopped up the #7 injector.
I cleaned out the fuel rails with carb cleaner. I cleaned the injectors by pushing a hose onto the top of each injector, squirting carb cleaner into the hose, hooking up some wires to the injector and touching them to a 9v battery so I could cycle the injector while blowing on the hose to push the carb cleaner through. Then, reassembled with some new o-rings.
Problem solved! No random engine misfire. A lot more power. And much better gas mileage.
97aztecgt
Aug 13, 2015 02:11 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
EscaTruck
Jul 20, 2015 11:42 AM
wheeliE-maxx
Jul 19, 2015 05:37 PM
