80e converter unlocking on freeway
Old Oct 2, 2015 | 10:08 AM
MikeD.'s Avatar
Default 80e converter unlocking on freeway
Finished my 80e swap in my sierra, and have a question on my converter unlocking at light throttle. So I have don't the research and know that I need to adjust my release speeds, but the problem is when I set them to 256, 256, and 0'ing out the last 4, it makes it not lock up at all after that? Everything else works great after using the bluecat tables (which are absolutely amazing). Any ideas?
Old Oct 2, 2015 | 10:11 AM
Vortec350ss's Avatar
The stock 80e file unlocks at 0% throttle regardless of apply and release speeds... i forget where you change that in the tune exactly. Does that sound like your problem? If so its an easy fix.
Old Oct 2, 2015 | 10:30 AM
MikeD.'s Avatar
Well I know that it's this table
But my issue is that when I do adjust it where it needs to be so it doesn't unlock, it actually causes it to stay unlocked on the freeway at all times. The unlocking doesn't bug me too much but I know it will get annoying after a while lol. First two boxes should be 256 and the last 4 should be 0% right?
Old Oct 2, 2015 | 11:08 AM
It will unlock when you hit the brakes no matter what those tables are set to.
Set the last 4 cells all to 0%.
Old Oct 2, 2015 | 04:25 PM
MikeD.'s Avatar
Every other post I see says to set the top two to 256 or maxed out essentially. But setting them as people say to still keeps it unlocked at less the 5% throttle
Old Dec 3, 2015 | 04:07 PM
Dans 05's Avatar
I have the same issue at 55mph if I just add a little touch of throttle it unlocks
mitchellmade
Sep 27, 2015 08:27 PM
sTNT971
Sep 11, 2015 02:38 AM
tgui
Sep 9, 2015 04:55 PM
Hpinnovate
Sep 4, 2015 02:28 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
