80e aftermath problem
Old Feb 14, 2011 | 03:01 PM
BadAssChevy327's Avatar
Default 80e aftermath problem
Just did 80e swap. Besides converter not locking till 65 I've had no problems.
But now I'm sitting on side of road on my iPhone. I was going down highway doing 75. Converter not locked. Had cruise on. Then I tapped brake to shut off cruise. My abs light and e brake came on then it said service brake system. So I slow down making sure I had brakes. All was good pedal wise so I did 60 to now exit. Then dash says transmission hot right as I get off exit. I make a eight to pull in a parking lot and it slams second gear hard and squeals the tires. I look under hood no signs of damaged wires. Then I let it cool for 30 mins. Start it up and no lights or anything.
Ive been keeping a eye on trans temp and it was normal. But I have another thread talking about how gauge shows 2 small notches above 100 even when truck ice cold. So I don't even know if gauge working right but somehow it knew it was hot.
Let me know any ideas you guys might think. I'm gonna hook it to a Matco scanner later and see. What exactly it did on brake code and figure out why it did it.
Old Feb 14, 2011 | 04:27 PM
It threw this code in the history.
C0558. It says no definition for it. But that was it. I'll do some looking. I think tran got hot cause converter never locked going down highway. But I'm sending computer back to Justin once he responds to email.
Old Feb 14, 2011 | 04:31 PM
smokeshow's Avatar
Mod with training wheels
Certainly sounds like a wiring/sensor issue. Sorry to hear it, man
Old Feb 14, 2011 | 04:36 PM
Did research. On efi live forum Dc Justin was having same issue with 3 other vehicles. I think it's causing this cause now traction control is disabled. Hopefully on retune this all gets fixed.
Old Feb 14, 2011 | 04:38 PM
Now to figure out why trans Gauge reads wrong. Everything hooked up right. It even shows 2 notches above 100 when truck is turned off when normally all of them read zero or all the way down. I think maybe the sensor in trans is different and gauge is reading it wrong
Old Feb 20, 2011 | 01:57 AM
1bad2k's Avatar
Did you ever get this issue figured out?
Old Feb 21, 2011 | 11:03 AM
I've had my computer back but I sent all my gauges and stuff out to get blue LEDs. As soon as they get back I'll report.
Old Feb 29, 2012 | 03:48 PM
Yohns Kustom Fab's Avatar
Formerly classic_speed (2015-06-02)
Well I now own this truck and the issue is still here. Put a rf abs sensor in cause it also showed it by code. Still no tcs. Still getting a code c0058.....
Any pointers guys?
Old Mar 21, 2012 | 08:08 PM
Ouch. That Hurt a little Travis lol
Old Mar 21, 2012 | 10:14 PM
Idk why. Its still got the problem and I'm trying to solve it. Looks like its because the ratios are off in the abs. I need to have the dealer tune it with a tech2
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
