6.0 wont start
Old Mar 26, 2007 | 01:22 PM
Tootall's Avatar
Originally Posted by 00Z71
So if the gaskets were on backwards it should still start, right.
Well on the good side of things it was nice to see my truck put back together after 3 months of it sitting there with no trans or motor. Just glad I did not loose and bolts, lol,
Hope to have the problem solved tonight.
yes it'll start, I had only one head gasket on backwards, the driver's side was on backwards. The temp gauge was all over the place.
Is your trans back in, everything plugged back up?
Old Mar 26, 2007 | 01:44 PM
Everything is back in, started up with Hp tuners hooked up and no codes.
I think I will put on the new 42 lbs injectors I have and give it a try
Old Mar 26, 2007 | 02:17 PM
Tootall's Avatar
dirt_track_racer_81 had some #30 injectors (30-31lbs) and they didn't even come close. You might ask him about them.
Old Mar 26, 2007 | 03:02 PM
The reason for the 42lber is that I plan to go forced induction soon.
Old Mar 26, 2007 | 03:09 PM
Tootall's Avatar
gotcha . . . what year PCM are you using? . . . I remember reading where the 99-00 had/has problems with knocking?
Old Mar 26, 2007 | 03:26 PM
TURBHOE's Avatar
got a dumb question you didn't hapen to get the wir harness backwards did you? that would make the spark 180 out i would think. does it have dbw throttle body? you didn't tighten the valve to tight did you? don't think you really can on these motors but its a thought. oh and are your push rods the right length? is there anything that could be holding the valves open?
Old Mar 26, 2007 | 05:20 PM
tarinitup's Avatar
9 Second Truck Club
I was there during the install and assembly and I know for a fact that the gaskets arent on backwards, and the timing was dot to dot. I spun the crank 3-4 extra times and the dots still lined up. I'm leaning towards the injector theory but I'll stop by after school to see if you have it whooped.
Old Mar 26, 2007 | 05:26 PM
TXsilverado's Avatar
when you say it starts to rev outa control, how high do the rpm's get before you kill it?
Old Mar 26, 2007 | 05:56 PM
3-4 thousand
Old Mar 26, 2007 | 06:21 PM
you said you already primed the motor right (oil circulated). if so let it go for a minute or so and see what happens. as long as theres not alot of rattling or backfiring...maybe its the computers way of making it run so it can figure out that idle. the first time i started my motor it wanted to idle at 1500 rpm after it got through the studders. after about 5 minutes it dropped to around 750. mine rattled its *** off for a while too. scared the crap outa me! make absolute sure you have oil pressure and watch the temps.
