5.3 truck cutting out and wot issues
#22
On the reman ecu's, could I still be able to use a handheld to adjust parameters as needed? Or any other tuned ecu for that matter? Like id like to get one tuned for what I got now (shorter tires and stuff) but id like to be able to still change it down the road with a predator tuner or somethin. I've got a predator for my ls1, and I like it.
#23
#24
11 Second Club
Im thinkin about swapping the ecu and seeing what happens. Im gonna see if the local salvage has one, if not I found one on ebay for 69 bucks. Is there any year range to look for, for a 99? Or certain model numbers to look for?
#25
And yes that is the valve I was talking about early, but no its not responsible for your issue.
I'm on a smart phone so some how things got all jumbled around...
#27
have you ruled out a knock sensor??? mine went bad on my truck and it pulled timing and fuel...didnt run rough but was really weak..maybe being a older model truck might make it react differently...ive herd that the trucks are notorious for it. usually the rear one
#28
Yes, un hook the ecu and flip it over. There should be a service tag with a number on it. Will say something like service number and hardware number. The one you want should be 09354896 for 99-00 models and it needs to have a similar calibration in it from an 8 cyl. Make sure that is the same number on your ecu.
