5.3 running terrible
Old Aug 9, 2006 | 06:54 PM
dirt track racer 81's Avatar
check your fuel filter, its the most over looked part..
Old Aug 9, 2006 | 10:27 PM
MrXerox's Avatar
Originally Posted by dirtdiggler02
Could it be a faulty ign. coil? It can have good spark at idle,then lose spark at higher rpm's
Im with you. bad coil or plug wire bad or loose.
Old Aug 10, 2006 | 12:01 AM
His is in the tank. I doubt that's the problem.
Jim
Old Aug 11, 2006 | 11:32 PM
LS1TRUCKGUY's Avatar
mine did the same thing intermittantly, mostly at highway speeds. i noticed it only did it for a split second before the a/c compresor cycled. i took the a/c belt off and turned the a/c on to rule out an electrical problem, and it was fine, ran great. the compressor was going out and trying to lock up as the compressor clutch engaged, causing a bog/shuttering problem. replaced thecompressor and its fine. does it make a difference if the ac is on or off?
Old Aug 12, 2006 | 09:51 AM
my 5.3 isnt running good either so im subscribing to this thread
Old Aug 13, 2006 | 11:51 AM
Texas Terminator's Avatar
11 Second Club
have you tried cleaning the MAF? what do the plugs look like?
Old Aug 13, 2006 | 10:18 PM
how do you clean the MAF? just a compressed air type cleaner like for computers or what?
Old Aug 13, 2006 | 10:20 PM
is there any way to test if you have a faulty ignition coil? i assume those are fairly expensive to just go and replace, any one have a part number?
Old Aug 14, 2006 | 09:39 PM
11 Second Club
very carefully. take the MAF out, get a can of electronic parts cleaner that won't leave any residue, and have at it. if you want to get more into it, grab a q-tip and CAREFULLY swab the wires, just don't break them.
Old Aug 14, 2006 | 09:41 PM
11 Second Club
if you have a scan tool like EFI live, you can do a cylinder balance test. other than that, pull your plugs, all of them, and see what they look like. if you have one that is black, then it's obviously got a problem.
