5.3 running terrible
mine did the same thing intermittantly, mostly at highway speeds. i noticed it only did it for a split second before the a/c compresor cycled. i took the a/c belt off and turned the a/c on to rule out an electrical problem, and it was fine, ran great. the compressor was going out and trying to lock up as the compressor clutch engaged, causing a bog/shuttering problem. replaced thecompressor and its fine. does it make a difference if the ac is on or off?
Originally Posted by Soon2bSpooled
how do you clean the MAF? just a compressed air type cleaner like for computers or what?
is there any way to test if you have a faulty ignition coil? i assume those are fairly expensive to just go and replace, any one have a part number?
