5.3 with ls1 cam and 3k stall tuning
I am curious on how to go about tuning for the ls1 cam in my 5.3 that I will be swapping in tomorrow. I read the VE tuning guide, and I do have a wide band to put in to monitor things as well. If I put the wideband in the rear o2 sensor spot, will that be fine ?
I am pulling my 4.8 out since its high miles and is burning oil now
so time for the 5.3. I also have a 3k stall to put in as well.
Does the truck still have the catalytic converters? If so you won't have "accurate" lambda (afr) readings after the cats.
If no cats on the truck though then the rear O2 position will work just fine.
ARC
57
Feb 21, 2022 10:54 AM
LCHEE
Oct 24, 2020 04:10 PM
Castro45
24
Jul 31, 2015 07:13 PM
