5.3 lm7 2003 silverado
Old Jul 14, 2016 | 05:20 PM
2002z28s's Avatar
Registered User
Default 5.3 lm7 2003 silverado
hi all new to the site I have a 03 Silverado engine im having the lm7 rebuilt and I wanted know if ill run into any trouble after my build .
so far I have stock dished pistons replaced my 862's have been milled
.35 for compression and im running a .39 ls1 gasket stock length PR
and isky bumpstick 222/234 560/570 112+2
will I have ptv issues with the heads and gasket combo ?
Old Jul 14, 2016 | 09:15 PM
Why such a huge I/E cam duration split for a 5.3?
Old Jul 14, 2016 | 09:30 PM
FFDP's Avatar
Racecar?
Old Jul 14, 2016 | 11:12 PM
BlueTexan24's Avatar
the split on that cam is way to big for cathedral port heads.
Old Jul 15, 2016 | 09:19 AM
Slow05CC's Avatar
Avery@texas-speed.com
If I did my math right you have around 56cc heads. To be completely honest I would check for PTV clearance? I feel like the intake will clear, but the exhaust might hang long enough to kiss your piston. If it were my build I would not chance it! DO the right thing and check the PTV!
Old Jul 15, 2016 | 11:09 AM
2002z28s's Avatar
Registered User
good running streetcar,and Im having my cam grinded now so what do you think would be a good split for my duration ? and I maybe wrong on the exact mill # but Im suppose to have 58cc to tell the truth I though the split on the cam was rather small
compared to a ls6 cam 204/218@.50 .550/.550 lift 117.5 LSA im kinda of new to this so forgive me if I sound like a noob the car is 3300 with me in it
Old Jul 15, 2016 | 11:29 AM
2002z28s's Avatar
Registered User
not sure if it makes a difference but I called my porter up he stated heads are milled to 58cc and 2.02 and 1.55 are installed on head
Old Jul 16, 2016 | 01:43 AM
upper 220 duration since your set up is so light. I'd limit the split to 4 degrees honestly. Like a 228/232
Old Jul 18, 2016 | 11:47 AM
2002z28s's Avatar
Registered User
thanks blue if you don't mind me asking why such a small split ?
Old Jul 18, 2016 | 11:49 AM
2002z28s's Avatar
Registered User
also the stall is 3200
