4l80e shift point tuning
Old Dec 6, 2017 | 12:31 PM
vidan27's Avatar
Default 4l80e shift point tuning
I recently did a 4l80e swap. The shift points just don't seem right for a performance application. Especially in normal mode. All it wants to do is shift immediately through all the gears. Performance (tow/haul) seems a little bit better. I was thinking of copying my performance tables to normal then and then adding a few mph to the performance side. Does anyone have any experience with this. Any help would be appreciated. Thank you
Old Dec 6, 2017 | 12:49 PM
FFDP's Avatar
Can you post the tune file?
Curious as to what it looks like now and what you can change.
Old Dec 6, 2017 | 01:04 PM
vidan27's Avatar
I have ateaches the tune file. I'm pretty sure it's a stock file 4l80e from a truck. Thank you.
Old Dec 6, 2017 | 01:10 PM
FFDP's Avatar
Try lowering the shift times and upping the shift pressure by like 5% at at time to see where it gets you.
Go for like .200 on the shifts and add a little line pressure. That should get it to shift firmer through the gear and not give it that small pause when it going into the next gear.
Old Dec 6, 2017 | 01:14 PM
vidan27's Avatar
OK. I will try and get that done. Not too familiar with HPT. Should I leave the shift mph vs tps alone?
Old Dec 6, 2017 | 01:28 PM
FFDP's Avatar
You can change that stuff up if you want too, just up to you on how you want it I guess.
If shifting at a lower mph or high mph if that is what you want, go ahead and adjust it to your needs.
Old Dec 6, 2017 | 01:37 PM
vidan27's Avatar
Thanks again for your help. I'll see what I can do. Need to figure out some other tuning issues first. Doesn't like to idle very well in drive. Goes into open loop with no stft. Runs rich then lean and wants to die.
Old Dec 6, 2017 | 03:10 PM
TrendSetter's Avatar
tuning shift and tcc speeds can be tricky.
there is a spreadsheet on the efilive site that plots them out and lets you visualize them. ive spent a decent amount of time getting mine right, and im pretty happy overall.
it just takes some time and experimentation.
Old Dec 6, 2017 | 03:16 PM
vidan27's Avatar
I will take a look at it tonight. Thank you
Old Apr 28, 2020 | 10:54 PM
RedXray's Avatar
100% Redneck
Originally Posted by StreetSmasher
Let me wake this thread up. I’m curious what happened. Digging into some shiftpoint tuning.
If you have HP Tuners just download and use the BLUECAT transmission tuning software.
