4l80e relay mod tuning tips
Old Dec 30, 2014 | 08:10 PM
UnVmy5.3's Avatar
Default 4l80e relay mod tuning tips
Just finished the 80 swap in a 02 I did the relay mod... running down the road driving normal it shifts perfect no issues... I deleted the codes needed my issue is at wide open throttle it shifts at 4500 1-2 then immediately 2-3 a roughly around 4000 rpm no matter what I command it to.... doss anyone have any tips or post their 80 swap on 60 tune
Old Dec 31, 2014 | 08:45 AM
May not help but copy and paste a 80e force motor current table in place of the 60e table.Also post your tune
Old Dec 31, 2014 | 09:30 AM
03sierraslt's Avatar
Never used the relay method, only segment swaps.
Also the EPC solenoid is the same between the 60-80e so the force motor table shouldn't matter.
Old Dec 31, 2014 | 10:31 AM
True but there is a big difference in values.
Old Dec 31, 2014 | 07:16 PM
Depends on year and model. Mine was damn near the same. It's just a shift pressure table essentially, so if you copy it then you need to copy shift pressures to get the same result.
Bluchevypick
Aug 18, 2015 09:11 AM
lo&sloSierra
Jul 19, 2015 04:21 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
slowlsx
Jul 13, 2015 04:18 AM
zaathur151
Jul 6, 2015 10:57 PM
