4L80E force motor
Old Dec 25, 2015 | 10:25 AM
Rick Predmore's Avatar
Registered User
Default Force motor 4l80e
Why am I unable to lower the values in my force motor tables?
Old Dec 25, 2015 | 12:45 PM
Registered User
Default 4L80E force motor
why can't i lower my force motor values?
Old Dec 25, 2015 | 01:01 PM
03sierraslt's Avatar
In the tune? What are you trying to do? Are you saying it won't let you?
Old Dec 25, 2015 | 02:01 PM
BlackGMC's Avatar
Resident Retard
I believe lowering that value actuly increases the overall pressure in the tune.
Old Dec 25, 2015 | 02:03 PM
It does, it works hand and hand with the shift pressures table.
Old Dec 27, 2015 | 10:06 AM
Registered User
when i tried to lower the last columm it would go back to previous setting not sure how but i fixed it thanks for the replies though
Old Dec 27, 2015 | 11:10 AM
You do know how that table works right? If not there are other tables that effect it and may not allow your changes to do anything. What's your max commanded line pressure value set at?
Old Dec 27, 2015 | 12:19 PM
Registered User
I've just began tuning gas i'm use to large caterpillar motors but anyway, i have the max pressure set to 96, shifts firm like i want shift times seem ok but almost seems as though it hunts a gear before shifting, might just me. were i screwed up is i copied someone else's tune and it's been messed up since. Like i said i almost have it were i want. Hell one guy posted zero out last row of force motor well i can tell you that was a mistake truck went to hanging till i lifted at wot. This is a 05 gmc 2500 hd 4x4 6.0
Old Dec 28, 2015 | 07:32 AM
madmann26's Avatar
Post the tune.
Did you license the PCM in order to make/save changes? Or is it that it just doesn't lower when you try?
Post it and I'll see if I can.
Old Dec 28, 2015 | 08:32 AM
Registered User
Default Force motor4l80e
Originally Posted by madmann26
Post the tune.
Yes i have a license. Through hp I pretty much have it were I like it,i just need to soften the shifts up some,it's pretty harsh. I added5 to the whole table exept last row which is back to factory settings works better that way in force motor
