4.8 LS airflow numbers for DeskTop Dyno
Old Jul 23, 2016 | 02:40 PM
Fullpower's Avatar
Default 4.8 LS airflow numbers for DeskTop Dyno
Trying to model LS4.8, stock truck heads TX Speed 212/218 114 lsa" low lift " Shorty headers.
Anyone here that can confirm my cylinder head airflow numbers, ripped from a Camaro Site This is what I have :
Stock 5.3 Heads
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
Valve Diameter Intake 1.89"
Valve Diameter Exhaust 1.55"
Part Number 12559852
12561706
Numbers seem within reason, reason, or out in space for stock cathedral port truck heads ?
Old Jul 23, 2016 | 11:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Those were likely copied from this site. A sponsor at the time put them on his flow bench.
https://www.performancetrucks.net/fo...g-info-434396/
Old Jul 24, 2016 | 02:35 AM
Fullpower's Avatar
I am trying to make a DeskTopDyno file,
4.8 LS with 862 heads,
TX Speed "low lift" 212/218 cam,
and Magnuson TVS1900 @ 6psi
Can't find exact valve event data for TX cams, but I DAMN sure like how they run in natural aspirated 5.3
Old Jul 24, 2016 | 08:00 AM
03sierraslt's Avatar
What cam are you trying to figure? Calculating the events at .050 is simple, however the .006 events would require lobe profile info.
Old Jul 25, 2016 | 07:19 PM
Fullpower's Avatar
I have purchased and installed (two) TexasSpeed 212/218 'Low Lift' camshafts, Neither furnished with a cam card. actual valve events are unknown.
The 5.3L natural aspirated performs very well in a heavy vehicle, with stock converter.
Trying to model same cam "Under Pressure".
I have email into Texas Speed, asking for detailed valve events.
See what they come up with.
Old Jul 25, 2016 | 08:40 PM
What LSA And advance?
Old Aug 15, 2016 | 05:37 PM
Fullpower's Avatar
LSA 114
Installed straight up.
Old Aug 17, 2022 | 11:44 AM
Fullpower's Avatar
Thread from the dead:
ANY body able to give airflow numbers for cathedral port Gen III 5.3 Truck heads ?
Old Aug 17, 2022 | 11:50 AM
1FastBrick's Avatar
See post #2 and follow the link.
Old Aug 17, 2022 | 01:08 PM
Fullpower's Avatar
Pasted from your link. Easier to find in bumped thread:
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Material: Aluminimum
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Thank you Brick...
foxnutz
Mar 12, 2016 10:13 AM
booboo37
Mar 4, 2016 07:54 PM
SweetNslow
Mar 27, 2002 10:40 PM
