2007 Tahoe wiring question
Old Feb 13, 2007 | 08:33 PM
cvman's Avatar
Default 2007 Tahoe wiring question
Not quite sure where to post this. I already posted a similar question at the LS1 forum in the conversion section. I just picked up a 2007 5.3 out of a Tahoe, for my 56 Chevy, and I plan to do the harness myself. Has someone mapped out the harness as far as what pin is what on the PCM?
Old Feb 14, 2007 | 10:46 AM
blown3qtr's Avatar
Don't know if it helps, but painless makes a harness for LS1's. SDPC has them.
Old Feb 14, 2007 | 12:06 PM
cvman's Avatar
Thanks! Who is SDPC? The reason I want to make the harness myself is I want to hide all of them, if possible.
Old Feb 15, 2007 | 04:49 PM
blown3qtr's Avatar
Scoggin Dickey Parts Center ( sponsor ). Nelson Performance also makes custom harnesses (sponsor).
Old Feb 15, 2007 | 09:12 PM
Grumpy5.3's Avatar
Default 07 tahoe pcm C1
Engine Control Module (ECM) C1
Connector Part Information
OEM: 15499466
Service: 88988931
Description: 73-Way F Receptacle 0.64 Sealed (BK)
Terminal Part Information
Pins: 73
Terminal/Tray: 7116-4152-02/9
Core/Insulation Crimp: A/5
Release Tool/Test Probe: 12094430/J-35616-4A (PU)
Pins: 1, 12-13, 16-17, 23-24, 29-36, 50-52, 56-59, 63, 68, 70-71
Terminal/Tray: 33467-0003/23
Core/Insulation Crimp: H/H
Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
Pins: 2, 9-11, 18-20, 27-28, 37-38, 41, 47, 49, 61, 64-65, 69
Terminal/Tray: 33467-0005/23
Core/Insulation Crimp: J/J
Engine Control Module (ECM) C1 Pin
Wire Color
Circuit No.
Function
OG/BK
1786
Park/Neutral Signal
GY/BK
1694
4WD Low Signal (NP8)
3-8
Not Used
L-BU/WH
6311
Brake Switch Signal
PU/WH
1668
HO2S High Signal - Bank 1 Sensor 2
11
TN/WH
1669
HO2S Low Signal - Bank 1 Sensor 2
OG/BK
380
A/C Refrigerant Pressure Sensor Signal
13
TN
5514
Low Reference
14-15
Not Used
16
PU
1589
Fuel Level Sensor Signal - Primary
17
D-BU/WH
473
High Speed Cooling Fan Relay Control
18
D-BU
5985
Accessory Wakeup Serial Data
19
PK
439
Ignition 1 Voltage
20
RD/WH
440
Battery Positive Voltage
21-22
Not Used
23
PU
1272
Low Reference
24
D-GN
890
Fuel Tank Pressure Sensor Signal
25-26
Not Used
27
TN
2501
High Speed GMLAN Serial Data Bus -
28
TN/BK
2500
High Speed GMLAN Serial Data Bus +
29
D-BU
1161
APP Sensor 1 Signal
30
BN
1271
Low Reference
31
TN/BK
6049
Low Reference
32
L-BU
1162
APP Sensor 2 Signal
33
GY
2709
5-Volt Reference
34
GY/WH
2700
5-Volt Reference
35
Not Used
36
TN
1274
5-Volt Reference
37
TN/BK
472
IAT Sensor Signal
38
TN
2760
Low Reference
39-40
Not Used
41
YE
492
MAF Sensor Signal
42-46
Not Used
47
PK/BK
1339
Ignition 1 Voltage
48
Not Used
49
TN
1671
HO2S Low Signal - Bank 2 Sensor 2
50
D-GN/WH
465
Fuel Pump Relay Control - Primary
51
TN
1465
Fuel Pump Relay Control - Secondary (Except NQZ)
52
YE/BK
625
Starter Enable Relay Control
53-55
Not Used
56
WH/BK
1164
5-Volt Reference
57
YE/BK
1827
Vehicle Speed Signal (JH6/JH7)
58
D-GN
335
Low Speed Cooling Fan Relay Control
59
YE
5991
Powertrain Relay Coil Control
60
Not Used
61
WH
1310
EVAP Canister Vent Solenoid Control
62
Not Used
63
D-GN/WH
459
A/C Compressor Clutch Relay Control
64
OG/WH
3223
HO2S Heater Low Control - Bank 2 Sensor 2
65
GY/WH
3122
HO2S Heater Low Control - Bank 1 Sensor 2
66-67
Not Used
68
BN/WH
419
MIL Control
69
PU
1670
HO2S High Signal - Bank 2 Sensor 2
70
Not Used
71
OG/BK
6399
Replicated TOS Signal
72
Not Used
73
BK/WH
451
Ground
Old Feb 15, 2007 | 09:13 PM
Grumpy5.3's Avatar
Default 07 tahoe pcm C2
Engine Control Module (ECM) C2
OEM: 13511426
Service: 19115670
Description: 80-Way F Receptacle 0.64 2.8 Sealed (GY)
Pins: 2-3, 16, 34-35, 41-53, 58, 63-69
Pins: 5-14, 17-33, 37-40, 56-57, 59-61, 70-79
Core/Insulation Crimp: Pins 5-14, 17-22, 29-33, 37-40, 56-57, 59-61, 70-79: J/J
Core/Insulation Crimp: Pins 26-27: K/K
Engine Control Module (ECM) C2 Pin
Wire Color
Circuit No.
Function
Not Used
PU/WH
6270
5-Volt Reference
GY
2701
5-Volt Reference
Not Used
BN
582
TAC Motor Control - 2
YE
581
TAC Motor Control - 1
Not Used
D-GN/WH
428
EVAP Canister Purge Solenoid Control
GY
5493
Cylinder Shutoff Solenoid Control (3) (LY5/LMG/L76/LC9)
D-BU
5491
Cylinder Shutoff Solenoid Control (1) (LY5/LMG/L76/LC9)
11
OG
5494
Cylinder Shutoff Solenoid Control (4) (LY5/LMG/L76/LC9)
GY/WH
3113
HO2S Heater Low Control - Bank 1 Sensor 1
13
L-GN
3212
HO2S Heater Low Control - Bank 2 Sensor 1
14
L-GN/BK
5492
Cylinder Shutoff Solenoid Control (2) (LY5/LMG/L76/LC9)
Not Used
16
PU
5284
Camshaft Actuator Solenoid Control (L76,L92,LY6)
17
D-BU/WH
878
Fuel Injector 8 Control
18
TN/WH
845
Fuel Injector 5 Control
19
YE/BK
846
Fuel Injector 6 Control
20
TN
1744
Fuel Injector 1 Control
21
YE
410
ECT Sensor Signal
22
TN
2761
Low Reference
23-25
Not Used
26
D-BU
496
Knock Sensor 1 Signal
27
GY
1716
Low Reference
28
Not Used
29
L-BU
1876
Knock Sensor 2 Signal
30
GY
2303
Low Reference
31
Not Used
32
GY
23
Generator Field Duty Cycle Signal
33
BN
1174
Oil Level Switch Signal
34
BK
2755
Low Reference
35
TN
2752
Low Reference
36
Not Used
37
L-GN/BK
1745
Fuel Injector 2 Control
38
PK/BK
1746
Fuel Injector 3 Control
39
L-BU/BK
844
Fuel Injector 4 Control
40
OG/BK
877
Fuel Injector 7 Control
41
GY
2705
5-Volt Reference
42
Not Used
43
GY
2704
5-Volt Reference
44
D-BU
6259
5-Volt Reference
45-49
Not Used
50
TN/WH
331
Oil Pressure Sensor Signal
51
Not Used
52
TN
2199
Low Reference (L76, L92, LY6)
53
OG/BK
469
Low Reference
54-55
Not Used
56
TN
1664
HO2S Low Signal - Bank 1 Sensor 1
57
PU/WH
1665
HO2S High Signal - Bank 1 Sensor 1
58
L-GN
432
MAP Sensor Signal
59
PU
1666
HO2S High Signal - Bank 2 Sensor 1
60
TN
1667
HO2S Low Signal - Bank 2 Sensor 1
61
BN
25
Charge Indicator Control/Charge Indicator Signal
62
Not Used
63
PU
486
TP Sensor 2 Signal
64
D-BU/WH
6265
CMP Sensor Signal
65
D-GN
485
TP Sensor 1 Signal
66
BN
6266
Low Reference
67
Not Used
68
WH/BK
6271
CKP Sensor Signal
69
GY/BK
6272
Low Reference
70
PU
2121
IC 1 Control
71
PU/WH
2128
IC 8 Control
72
OG
2127
IC 7 Control
73
OG/WH
2122
IC 2 Control
74
L-BU/WH
2126
IC 6 Control
75
D-GN
2125
IC 5 Control
76
D-GN/WH
2124
IC 4 Control
77
L-BU
2123
IC 3 Control
78
BN
2129
Low Reference
79
BN/WH
2130
Low Reference
80
Not Used
Old Feb 15, 2007 | 10:02 PM
cvman's Avatar
WHOA! Thanks Grumpy! WHere do you find that info? That is for the 07 Tahoe?
Old Feb 15, 2007 | 10:19 PM
Grumpy5.3's Avatar
yes that is for the 07 tahoe, its 4wd, you didnt specify, they should be the same though.... working at the stealership has its perks
If you need anything else let me know
Brian
Old Feb 15, 2007 | 10:23 PM
cvman's Avatar
That's great to know, thanks for the awesome information. I was reading somewhere about the V4 system, does this one have it? Yes. it's a 2wd.
Old Feb 17, 2007 | 07:59 AM
blown3qtr's Avatar
WOW
