2003 v6 to 5.3 dbc od dbw
QUESTION ?? doing a a swap .In yall opinion which would be easier dbc or dbw . The 2003 WERE dbw but the v6 were dbc . i have both complete harness out of donor vechicles
DBC is less complicated IMO but you'll need a P59 ECM that has the IAC (idle air control) chip... some do some don't. You can run the P01 ECM (cable only) but you'll need to swap the green harness connectors for the red.
https://www.youtube.com/watch?v=e7A1hhx7f0A
If you have a 03+ P59 ECM with part number 12576106 it should have the IAC chip (open case to verify) to use with either a DBC or DBW setup. These are hard to find and are usually in the Express Vans and GTO's.
Kevinj562
Sep 28, 2024 09:59 AM
brandon6.0
Feb 3, 2017 08:31 AM
brandon6.0
Feb 1, 2017 06:38 PM
