2 step question with LNC-2000
Old Aug 30, 2013 | 12:54 AM
2doorfury's Avatar
Default 2 step question with LNC-2000
Is there a way to hook up the 2 step on a foot brake? Or does it only work on a trans brake or line lock?
Old Aug 30, 2013 | 07:35 AM
Chevy_King1500's Avatar
you can put it on a momentary push button
Old Aug 30, 2013 | 09:00 PM
2doorfury's Avatar
That's what I was thinking. What about one of those nitrous buttons that goes under the gas pedal. But instead put it under the break peddle??
Old Aug 30, 2013 | 09:14 PM
kbracing96's Avatar
Yes, When I had one, I just tap the trigger wire into a hot wire on the brake light switch. Brake lights on = 2 step on.
Old Aug 30, 2013 | 09:42 PM
Byrdman11's Avatar
And think the same as KB Racing.
Old Aug 30, 2013 | 10:31 PM
oakley6575's Avatar
So you are able to run an arming switch to the two step? Then once you arm it, the brake pedal becomes the trigger?
Old Aug 31, 2013 | 01:14 AM
2doorfury's Avatar
That's the impression I'm getting. That's how I was thinking it would work. The arming switch is put under brake peddle. When brake peddle is applied, 2 step engages. When let off it turns off
Three6GMC
Aug 27, 2015 03:53 AM
lxcoupe
Aug 22, 2015 08:23 AM
bighouse
Aug 14, 2015 08:00 AM
hirdlej
Aug 10, 2015 10:51 PM
USMCvet0311
Aug 1, 2015 07:45 AM
