1999 Silverado 5.3 4wd injectors
Old 02-14-2012, 08:51 PM
Registered User
2StrokeJim's Avatar
So far so good..I think the f.p.r. may have taken care of it !!!!! Sweet!
Old 02-16-2012, 11:01 AM
TrickyTransAm's Avatar
And the answer to your earlier question is No, you cannot swap in the injectors from the later year in the 99 without changing the PCM programming.
Physically you can interchange them, but the electrical properties and flow of each are different.
1999's had 19lb/hr injectors
2005's most likely have 24lb injectors, so it may run, but may have issues or run lean/rich.
1999 was the poopy year with smaller injectors. 2000 up have 24lb injectors in the 4.8/5.3/6.0L trucks.
Old 02-16-2012, 08:19 PM
Registered User
2StrokeJim's Avatar
Default problem fixed
Changing fuel pressure regulator took care of my problem !
Jakejack
01-08-2024 10:44 PM
Vash3233
09-22-2019 01:18 PM
zo6freak
14
10-18-2015 06:43 PM
04450r
07-24-2015 01:58 AM
samg430
07-20-2015 10:12 AM
Quick Reply: 1999 Silverado 5.3 4wd injectors
