1-2 Shift Too hard, How to fix?
Old Oct 7, 2008 | 09:24 AM
MrXerox's Avatar
Default 1-2 Shift Too hard, How to fix?
Hey gang, got a quick question. Traded my stock 60e tranny in my 03 Silverado with a built one from Mad Dog transmissions. I have removed all tq mgmt and am happy with everything except for the 1-2 shift. Even at part throttle it kicks like a mule. Not sure how many washers are in the shift kit and I have not altered any line pressures or anything like that, it is all still stock at of now. Is there any way for me to safely remove some of this kick? It gets rather annoying on a daily driver
Wilde Racing posted on another forum that I need to go to "Trans> Shift Properties> Shift Pressure Modifier Upshift> 1>2
You can also go into the force table, but I feel it is best to leave that super blunt table alone unless you need line pressure changes throughout..."
Can someone please give me an example of some values I can try here? I dont mind the shift being hard at full throttle but would like it to be smooth at partial if possible. Thanks for the help on this!
Old Oct 7, 2008 | 09:29 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
You can take some out of the shift pressure table (where I'd start), the FMT and the Modifier tables. I'd start with the shift pressure table myself
Old Oct 7, 2008 | 10:51 AM
charcold-bowtie's Avatar
start with the pressure table. Look at the difference from stock to performance if your need a numerical value to use. IE. you know how much harder it shifts with tow-haul mode and say the difference in the columns is a value of15, subtract that off of the normal mode to tone it down a little. I dont know any numbers im not on my computer lol.
Old Oct 7, 2008 | 05:57 PM
silver-mod-o's Avatar
Hunt&Fisherator
You can go into shift timing and slow it down a hair as well in the part throttle cells. Not too much or it will begin to feel sloppy but just a bit coupled with pressure changes will make it feel more tame daily driving.
Old Oct 7, 2008 | 06:58 PM
viciousknid's Avatar
Where's the Beef?
Mad Dog offers 3 shift stages. 1: stock. 2: Firm and 3: Hard (neck breaking)
Which one did you get?
If you got stage 3 i'd lower the shift pressure and see if it helps. if it doesn't your going to have to drop the pan. When they do the stage 3 they modify the valve body along with adding the shift kit.
I think i got stage 3 on my blazer but I can't remember. Haven't driven it yet either
Old Oct 7, 2008 | 07:14 PM
MrXerox's Avatar
Its a stage 2 and you better hope you did not get a stage 3 is all I can say. It was kinda cool at first but it gets old rather fast when ANYONE that rides in your truck thinks the tranny is about to blow up
Here is my current tune that I have pieced together but the 1-2 shift is still too hard...Thanks for the help guys!
File Type: hpt
Old Oct 8, 2008 | 08:50 PM
Where's the Beef?
I'm pretty sure I got a stage 3 but can't remember. No big deal for it tho since it's a v8 conversion 4x4 that I'll just use to offroad in every once in a while.
Old Oct 8, 2008 | 09:00 PM
BlackGMC's Avatar
Resident Retard
I was in a similar situation, what I did was copy the 2->3 trans pressures and pasted them in the 1->2 trans pressure table... Seemed to help...
ferrellrooster
Mar 6, 2025 03:22 PM
Tx98Formula
Sep 10, 2015 01:03 AM
Fast86z
Aug 23, 2015 12:35 AM
Ferocity02
Aug 7, 2015 08:50 PM
