05 gmc sierra throttle pedal module
Old Jul 8, 2009 | 01:12 AM
tko889's Avatar
Registered User
Default 05 gmc sierra throttle pedal module
I have an 05 Sierra with throttle sensor issues. I was able to get an 06 gas pedal with wire and sensor. Will it fit the 05 TAC computer? Do any changes need to be made to make it work? I am assuming the module under hood is the same?
Thanks!
Matt
Old Jul 8, 2009 | 02:15 AM
Wheatley's Avatar
Truck Sponsor
The TAC Modules are not the same.If you hook a 06 pedal assembly and harness to a 05 TAC module,after a few seconds of driving it will go into limp mode!!You must have an 06 TAC.
06 is when they changed the pedal design
Old Jul 8, 2009 | 03:07 AM
tko889's Avatar
Registered User
Thank you for your response! I really appreciate that! If I get the TAC module as well, is there any other changes I would have to make?
Old Jul 8, 2009 | 03:10 AM
tko889's Avatar
Registered User
Also, it is going on a 6.0L, is there any calibrating for that needed?
Dan Neumann
11
Aug 7, 2022 09:06 AM
GXPJAY
Feb 13, 2022 08:15 AM
mhorn0817
Mar 6, 2016 08:00 PM
lawhitediamante
Aug 12, 2015 12:14 PM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
