04 silverado trans temp programming
Old Apr 6, 2014 | 10:19 AM
rt4x4's Avatar
Default 04 silverado trans temp programming
Would anyone one know the procedure to tell the dealer to turn the trans temp on in the cluster? My dealer is willing to do it they just don't know how?
Old Apr 6, 2014 | 10:46 AM
BOSS302's Avatar
did you swap to a cluster w/ the gauge? If so, it should be plug and play.
Old Apr 6, 2014 | 11:07 AM
rt4x4's Avatar
No I added the stepper motor,I just didnt want to send it off to be programmed,I was wanting the dealer to do it,they need to know how to do the procedure.
Old Apr 6, 2014 | 11:13 AM
BOSS302's Avatar
it's not a matter of programming, it's a matter of wiring. The pin is already hot, you just have to connect it.
Old Apr 6, 2014 | 11:25 AM
rt4x4's Avatar
I believe it is wired correctly,everyone I have talked to says the cluster needs to be programmed to turn on the trans temp gauge,some will already work and some won't,mine does not.,I was wanting to know the procedure using a tech 2 at the dealer to reflash to cluster.
Old Apr 6, 2014 | 11:32 AM
BOSS302's Avatar
Check your connections. All gmt-800 1500s are wired for the trans temp. It is plug and play, if your connections are correct.
Old Apr 6, 2014 | 11:35 AM
rt4x4's Avatar
I read that it works by just adding the stepper motor on some but not on others,they had to have them programmed.
Old Apr 6, 2014 | 12:08 PM
1FastBrick's Avatar
Custm2500's Rude Friend
If the cluster did not have the trans temp, it may have to be programmed with software from a VIN that had the trans temp in order to activate it.
Unfortunately the guys that know how to do it wont share the info.
Old Apr 6, 2014 | 04:40 PM
rt4x4's Avatar
Thats what is was wanting to know as to what to tell the dealer the steps on flashing the cluster.
Old Apr 6, 2014 | 04:52 PM
1FastBrick's Avatar
If I had to guess I would say there using a VIN from an HD truck of the same year to program the cluster.
ferrellrooster
Mar 6, 2025 03:22 PM
ullose272
Aug 5, 2016 02:05 PM
Bluecollar Hotrods
Jul 26, 2015 09:56 PM
85SS/85GN
Jul 22, 2015 12:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
