03 Chevy 1500 engine swap, 5.3 to 6.2, start issues
Old Aug 11, 2016 | 08:55 PM
legerwn's Avatar
Default 03 Chevy 1500 engine swap, 5.3 to 6.2, start issues
Was helping a buddy swap his 5.3 to a 6.2 today
Got everything hooked up and tried to start it, we had fuel but no spark. We rechecked everything as far as the harness but found nothing that would prevent it from firing.
Any ideas on what we need to check?
The truck harness was used along with the PCM I believe,
Thanks for any ideas
Neal
Old Aug 11, 2016 | 09:01 PM
FFDP's Avatar
Which computer are you using? The 5.3 or 6.2?
Did you swap reluctor rings or are you using a converter box?
Old Aug 11, 2016 | 09:52 PM
legerwn's Avatar
using the 6.2 reluctor,
buddy said he checked it and its a 24X reluctor
he used the 5.3 PCM
Old Aug 11, 2016 | 11:08 PM
FFDP's Avatar
The GEN 4 6.2 reluctor wheel is a 58x, it's for sure not a 24x.
I feel this is the major problem.
Old Aug 11, 2016 | 11:12 PM
1FastBrick's Avatar
Custm2500's Rude Friend
PCM vin needs to match the trucks vin.
6.2 is going to be a 58X unless someone was inside of it.
Old Aug 12, 2016 | 01:29 PM
legerwn's Avatar
The PCM matches the truck as it was the original PCM for the 5.3
The word my buddy got was that the 6.2 came in both versions a 58X and a 24X reluctor
He said he checked it and it is a 24X reluctor,
I was not there at the time he checked it nor do I know much about these motors,
I'll talk to him about how he verified the reluctor wheel,
FFDP, did the 6.2 ever come with the 24X reluctor?
Appreciate all the help,
Neal
Old Aug 12, 2016 | 01:38 PM
1FastBrick's Avatar
The early gen4 6.0's could be either or such as an LS2 engine. By the time the 6.2 was released it was only 58X being used.
Old Aug 12, 2016 | 01:40 PM
1FastBrick's Avatar
Look at the crank sensor. Grey is 58x black is 24x.
Pull the sensor and look at the wheel.
24x is 2 piece with staggered teeth. 58X is 1 piece wheel with consistent teeth.
Old Aug 12, 2016 | 01:48 PM
legerwn's Avatar
I'll find out how they verified the wheel and check the sensor to see what color it is,
thanks Neal
Old Aug 12, 2016 | 10:06 PM
legerwn's Avatar
they pulled the crank sensor and verified the reluctor was a 24X wheel so someone changed it. The crank sensor is black so that should be the correct one, they are going to replace the crank sensor with the original from the 5.3 and see what happens.
Neal
