02 HD Turbo Update wiring and more wiring
Old Jul 7, 2005 | 01:43 PM
NXRICKY's Avatar
Former Vendor
Default 02 HD Turbo Update wiring and more wiring
Ok, its been a little while since my last update. The 4" inlet to the Throttle body is now 3" looks alot cleaner than the 4" did, in my opinion. Dual channel wide band is install. One sensor before the turbo and one after. We are testing the deference pressure has on the sensors, and then we will be able to set them up so I can run both sensors before the turbo and see which bank of the engine is off.
That simple install took my all day, with disassebley the intire system so I could weld the bungs in, (forgot to it while fabit it out. ) Also look for that small exhaust leak that was bugging me , Found it, and its fixed. Quite as a stock truck.
With the efi live hooked up so far no knock, Now I have not nailed it but, you can tell the truck wants to haul it... Blow 2 air hoses off just playing around..
Fuel plate showed up and is installed, now just waiting to make all final connection wires, and drive it.
If you install an FJO wideband do not drive the vehicle until you make all the connections and it can power up. Did not notice that until reading the instruction and got to page 3 I think.
I should have some pice tommorrow.
Ricky
Old Jul 8, 2005 | 03:00 AM
GoldenVelvet's Avatar
03chevytruck
Nov 7, 2016 04:43 PM
greedygenius
Sep 3, 2015 06:51 AM
wrb002
Aug 31, 2015 12:00 PM
slowlsx
Aug 4, 2015 10:04 PM
