00 1500 starting problem
Old Mar 28, 2007 | 06:42 PM
fedman06's Avatar
Default 00 1500 starting problem
i have a completely stock 00 Z71, it doesn't like starting when its been sitting, something with the fuel? after you try to start it, then shut the key off and start it again it'll start, just seems like its not getting fuel at the first time. It happens everytime you go to start it the first time. if you shut it off and turn it right back on, there is no problem. thanks for the help
Old Mar 28, 2007 | 09:15 PM
negativeswitches's Avatar
try turning the key to on and then waiting 5 seconds then starting it
if it fires right up i'd say yeah the fuel pump is going out
Old Mar 28, 2007 | 09:50 PM
Flyer's Avatar
Could also be the pressure regulator. If the seals are going out in it, then the rail doesn't stay pressurized and the engine isn't getting the fuel it's needing.
Old Mar 29, 2007 | 12:32 AM
BlownChevy's Avatar
blownerator
25 Year Member
i am 100% sure it is the fuel pressure regulator as Flyer stated.
Old Mar 29, 2007 | 03:54 PM
fedman06's Avatar
Thanks guys, i have a fuel pressure regulator ordered, should be here tomorrow!
ferrellrooster
Mar 6, 2025 03:22 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
thunder550
Oct 8, 2015 04:53 PM
Denali man
Jul 19, 2015 03:52 PM
