Turbo 2007 NNBS Silverado RCSB
$16000
Here is the link to my on going project:
https://www.performancetrucks.net/fo...velope-527991/
I came across another project i am interested in,but would like to sell this first.
NOT PARTING OUT.
Running great at about 10lbs of boost,needs more fuel pump!
Truck:
2007 Chevrolet Silverado 1500 NNBS Reg.Cab Short Box
Base truck with carpet,A/C,CD,PL and keyless entry,G80-3.23:1
Interior about 7/10
Autometer 2&5/8 liquid filled boost gauge,AFX/NGK/NTK Wideband,Turbosmart in-cabin boost controller
Body is scratched up and dented but no holes
Front Suspension;Belltech struts and spindles no front sway bar
Rear Suspension;Diff. flipped,Static kit,Calvert 9 way shocks,helper leaf and spacer block removed
Engine:
4.8 Rotating assm.not touched
Comp.Cam 214 int. 226 exh. .559".569" 115 lobe sep.,LS7 lifters,LS2 timing set/damper
Pro Comp head studs,GM MLS gaskets,fresh 243 heads resurfaced -.030",PAC 1208x valve springs with Ti retainers
-12 drain welded in pan,oil pump spring shimmed
Holley Hi-Ram,LS9/ZR1 Injectors and MAP(Caspers adpt. harness),Stainless/Teflon fuel line/crossover
Jaz catch can
Turbo Set-Up:
Trick stage 4 Stainless hot side,MP T76 turbo,Precision PW39 wastegate,DEI blanket,Stage 8 header bolts,Vibrant Stainless muffler/down spout
Procharger 4 core intercooler,Tial blow off valve,3" aluminum piping
Stainless/Teflon -4 and-10 feed and drain lines
Transmission:
Fully built 4L65E
Everything Sonnax has to offer including Billet Input/output shaft and drum,new 1st/2nd ratio gear set
Deep Hughes Pan
10" 3500 billet cover multi disc,lock-up converter
This trans should be considered a MAX level build!
Wheels:
Bogart D10
15x11.5" and 17x4.5"
295/65-15 MT Drag Radials and M&H 4.50x28-17"
Gorilla wheel lock system
The majority of the parts were new for this build!
4300lbs
Idle vid:
http://vid148.photobucket.com/albums...psxg9ik0xt.mp4
Would be willing to meet on the U.S. side,northern NY
NOT PARTING OUT.
Truck:
Interior about 7/10
Engine:
Jaz catch can
Turbo Set-Up:
Transmission:
Fully built 4L65E
Deep Hughes Pan
Wheels:
Bogart D10
4300lbs
Idle vid:
