Turbo 2007 NNBS Silverado RCSB
1 Attachment(s)
$16000
Here is the link to my on going project: https://www.performancetrucks.net/fo...velope-527991/ I came across another project i am interested in,but would like to sell this first. NOT PARTING OUT. Running great at about 10lbs of boost,needs more fuel pump! Truck: 2007 Chevrolet Silverado 1500 NNBS Reg.Cab Short Box Base truck with carpet,A/C,CD,PL and keyless entry,G80-3.23:1 Interior about 7/10 Autometer 2&5/8 liquid filled boost gauge,AFX/NGK/NTK Wideband,Turbosmart in-cabin boost controller Body is scratched up and dented but no holes Front Suspension;Belltech struts and spindles no front sway bar Rear Suspension;Diff. flipped,Static kit,Calvert 9 way shocks,helper leaf and spacer block removed Engine: 4.8 Rotating assm.not touched Comp.Cam 214 int. 226 exh. .559".569" 115 lobe sep.,LS7 lifters,LS2 timing set/damper Pro Comp head studs,GM MLS gaskets,fresh 243 heads resurfaced -.030",PAC 1208x valve springs with Ti retainers -12 drain welded in pan,oil pump spring shimmed Holley Hi-Ram,LS9/ZR1 Injectors and MAP(Caspers adpt. harness),Stainless/Teflon fuel line/crossover Jaz catch can Turbo Set-Up: Trick stage 4 Stainless hot side,MP T76 turbo,Precision PW39 wastegate,DEI blanket,Stage 8 header bolts,Vibrant Stainless muffler/down spout Procharger 4 core intercooler,Tial blow off valve,3" aluminum piping Stainless/Teflon -4 and-10 feed and drain lines Transmission: Fully built 4L65E Everything Sonnax has to offer including Billet Input/output shaft and drum,new 1st/2nd ratio gear set Deep Hughes Pan 10" 3500 billet cover multi disc,lock-up converter This trans should be considered a MAX level build! Wheels: Bogart D10 15x11.5" and 17x4.5" 295/65-15 MT Drag Radials and M&H 4.50x28-17" Gorilla wheel lock system The majority of the parts were new for this build! 4300lbs Idle vid: http://vid148.photobucket.com/albums...psxg9ik0xt.mp4 Attachment 90897 Would be willing to meet on the U.S. side,northern NY |
Ttt!!!!
FYI The link for your project isn't working. Nice truck! Wish I was in the market but I'm just dreaming at the moment.
Originally Posted by PGdynamics
(Post 5309216)
Offers!?!?
Dang man, no one up in Canada wants that beast? That's a good pretty dang good deal... good luck with selling it man. Surprised you haven't yet...
Originally Posted by lycominghunter
(Post 5319437)
Trade for my 05 rcsb + mucho cash?
This is a good deal on a nice truck.
Originally Posted by Turbo09
(Post 5333312)
